How to create System Disk Repair in Windows 7?
I am running Windows 7 Professional. I need to know how to create System Repair Disk so I don’t need to reformat or re install Windows again and again when I encounter problems with my computer system again.
Can anyone here help me and send me instructions on how to properly make a disk, wherein I can use it to repair failure on my Windows 7.
Thanks in advance.
Best Answer by miley scott
Answered By 0 points N/A #98648
The newer version of Windows is much more stable than the previous releases. Windows 7 has a special feature that will let you create System Repair Disk in case you will need it to recover your operating system.
To create System Repair Disk:
1. Click Start and then type system repair disk into the search box.
2. The Create a system repair disk dialog box will open. Select the correct drive. The repair disk will take 142 MB of space only. So it is okay to use a CD. Just insert it to your optical drive and click Create disk.
3. When it’s done, take out the CD and keep it for future use.
When you encounter problems with your Windows 7, just boot from your System Repair Disk and enter Windows Setup [EMS Enabled].
When you are done booting from the disk, you can access recovery tools or you can restore your computer back to a system image.
system recovery options
Choose from the different recovery options to make your computer run again.
startup repair
Restart or shut down your computer and follow the on screen instructions depending on the option you choose.
Answered By 0 points N/A #98649
System recovery options can assist you to repair Windows if a serious error occurs. To use system recovery options, you'll need a Windows installation disk or access to the recovery options provided by your computer manufacturer. If you don't have either of those choices, you can create a system repair disk to access system recovery options.
It’s a simple solution.
You just have to follow instructions given below-
  • Click on the Start menu-> open backup and restore from control panel-> System and Maintenance.
  • In left hand side of the pane you’ll see the Create a system repair disc. Click on here and follow steps appear afterwards. You may be asked for administrator password and provide it then.
Answered By 10 points N/A #98650
Thank you, sincerely. You are all very proficient. And the site is incomparable.
