How to create tables and column in ms word
There are many tools in the Microsoft Office. Microsoft Office is the most important part of the computer. You have to learn Microsoft Office. Nowadays Microsoft is needed for different kind of official and personal work. You have to do many work in the Microsoft word. It is one of the most important part of the Microsoft Office.
To create table in Microsoft Office 2007:
To create column in the MS Word '07:
Select Table in Main Menu and click Insert and Select Table. And give required number of rows and columns details and press OK. Then table will insert in to Word file.
Fortunately we have menus in the MS Word software and we are easily can able to use File menu, Edit menu, View menu, Insert menu, Format menu, Tools menu, Table menu, Windows, Help.
There are many sub menu, sub-sub menus which is interact each other to do a document with the manner of computer software. I'm surprised to learn the subject of your question. Because I haven't any idea on MS Word formerly. I have learnt MS Word.
I have inquired and understood that this is not an easy matter to do the job accurately.
