How to create text effects software for PSD files?
I have an idea to create text effect software to add test effects to psd files which contain font where absence of Photoshop. This software should be able to edit any font type. Already I have collected some resources and if you are a expert of this please share your valuable ideas with me. Thank you..
Answered By 0 points N/A #194938
Hallow Kristi,
I am very glad to get your such a interesting question.
The Adobe Photoshop program is written in specially C++ language .To develop this program as well as it's program file you have to know the C++ language strongly .
You can create some library function by C++ for Photoshop.But it is not sure that it will work for adding text effect.
You can download C++ source code from http://www.mycplus.com/source-code/cplusplus-source-code/common-text-transformation-library/ This code is designed to modify text alignment ,using symbol in text etc. You can develop and deploy it  yourself.
However if you want to create a text effect by another program then the best option is "texteffectsoftware" which can be found from this link,just click to download :http://www.texteffectssoftware.com/pdl/TextEffectsTrial.zip
User Guide can be found from http://www.texteffectssoftware.com/support/
Thank you
Shifflet Laurel
