How to create time table internet in vb6 which will allow the user to use internet based on the pre determined time, which will be helpful to avoid internet addiction among children as well as adults. Please do the needful for providing tips for creating the same. Thanks, Archer Schleifer
If I am not mistaken you're looking for some support in building a web browser than can set a time-schedule to the user's browsing experience.Â
Firstly, I would suggest that you get a feel of what kind of functionalities you want to embed in your application by checking out already existing applications like BrowserControl.
Secondly, watch and learn how to create the various parts of your application like the timer, the browser, etc.
Finally, create your application and trial it until you think it's ready for duty. Good luck!
1....
