I want to add animated title in my html program, but I didn't know how to code it.
I want a sample codes of a title scrolling from right, and have blinking words on the title.
Can you show me some codes that will result on this?
How to create a title that moves?
Animated Title For Website :
Sometimes we need to add animated title, heading, footer in our website.
Sometimes we need to show some text which are moving or scrolling .
This function name is MARQUEE which can scroll any text in the website by HTML coding.
Let we try to apply it here.
At first write
 <marquee> </marquee> Just  put your required text in middle of function.
If you want to manage scroll time then just write –
scrolldelay="60" (Here you can put another value for fast and slow action.)
You can manage text scroll amount by write –
scrollamount="3"Â (Here you can put another value for change amount or repeat text.)
Example :
<marquee scrollamount="3" scrolldelay="80">
<div align="left"> TechyV.com</div>
</marquee>
