How to create a tv stream using vb?
How to create a TV stream using vb and will the latest visual basic version can be more compatible to my new operating system mac os x lion?
I need some advise on the right operating system that will be compatible to my visual basic programming language software.
Best Answer by Mundo Villaro
Answered By 0 points N/A #149824
Hello Damon,
It is quiet awkward that you will use operating system which will not support visual basic. Visual basic is Windows based IDE for BASIC programming.
If you will engage in Visual Basic programming you have to use Windows Operating System. Windows 98 to windows 7.
In anyway, I can help you with that.
Try this sample codes, you may want to benchmark with this project they have submitted.
HTH
Answered By 0 points N/A #149825
You can find the exact solution to help you create a TV stream using VB on this site.
I highly recommend that you visit and watch this video:
Also, it would be a good idea to go to this site:  Look around all you want to in order to find the best software for your business.
Have an advantageous day.
