How to create tv stream using vb programming language?
I am a fan of using visual basic programming language and want to know more about it.
I need to create and add in my program a TV stream.
Do you have some sample codes download links can you share it with me for reference?
Thanks
Best Answer by Fraserr thor
Answered By 0 points N/A #160007
Hi Nicko,
You may want to see the content of this link. https://www.techyv.com/questions/how-create-tv-stream-using-vb/ Furthermore, you can visit the site planet-source-code, programmers heaven, source codester for more free source code.
Answered By 0 points N/A #160008
Visual Basic was released by Microsoft. It was created for making programming easier than before. It contains some tools by default so that you will have no need of facing much difficulty. Visual Basic does not contain only programming language tools, but also a total graphical development environment.
It helps developers to complete creating any applications with just a little knowledge.
Visit the Microsoft website for Visual Basic tutorial and try all by yourself to insert a TV stream into your program.
It will help you much in the future.
