How to create udf openoffice?
Hello experts,
How to create udf open office? This is very important for me to learn more about this but it is easier if there are some applications that will give me a free template as a basis or reference to create an instance. Share your brilliant ideas and opinions with me it is a big help.
Thank you.
Answered By 5 points N/A #178503
UDF stands for User Defined Functions in Open Office. You can create your own UDFs using Basic IDE and be advised that this also requires that you have at least basic programming skills. To make your UDFs in OpenOffice, first go to Tools then Macros then click Organize Macros and lastly click OpenOffice.org Basic.
Click the Edit button to bring out the Basic IDE, you can now enter the function codes that you want, close the Basic IDE window to automatically save the function.
