How to create user account with security.
this is a simple thing my dear. First you have to go to start menu then control panel. Then there is a dropdown menu in upper hand corner in right side called "View by" select "Category" from that menu. Then you can easily see there is a link button called "Add or remove user accounts" under “User Accounts and Family Safety”. Click on it and you will direct to user account creation window.
You can see a link called “Create new account” in the left side and click it. Then give a name for account and click create account button in the bottom.
Hi Ramananth,
This is very easy task which you can be able to do when you follow the following steps with me.
a) Go to start menu at the right bottom corner and click on it.
b) On left hard corner of the start you will be able to see starting from down
Shut down
Help and support
Default programs
Devices and Printers
Control panel
Computer
Music
Pictures
Documents
c) Click on the control panel and you will be able to see the following icons
System and security
Network and internet
Hardware and sound
Programs
User account and family safety
Appearance and personalization
Clock language and region
Ease of access.
d) Click on User Account and family safety
e) Go to user account and check on add remove user.
Create account for the administrator and put password you can easy to remember
