How to create vbulletin member list
I want to know about creating vbulletin member list.
I am fairly a new user so do not know much about it.
Please tell me how to create vbulletin member list and how to use it.
Hi Levi Jeensen,
To make a member list, login to the program and import a list of members from your computer.
After importing you can add or delete the list according to your need.
Another way to make a list, use the ‘Add User’ option. After adding any member do not forget to save it.
How to Build & Import a Member List on Vbulletin
Vbulletin is a program by using which allows you to manage your website right from your computer.
To create member list I will suggest you to take following steps:
1. Load database to Vbulletin and check for available users.
2. To create new member click on Add Member and add new members to your database.
3. This way you can create members list on Vbulletin
