How do I create visual sitemap thumb so that I can navigate HTML files in my website easily? Is there a command or software for this? I still use Windows XP 64 bit Sp 2 and Mozilla Firefox 18.0.2 browser. Suggestions and feedbacks would be a great help.
How to create visual sitemap thumb?
Hello Young!
I suggest you pick up “WriteMaps”. It can create a visual sitemap thumb. You will be able to navigate your HTML files easily here. After all, you have to follow the process like:
After installation of “WriteMaps”, go to file menu and choose create a new page.
Then you after creating an account, it will automatically create HTML sitemap. As well as you will get unique URl for the publicity of this site map. Best of luck!
