How to create a Windows image for deployment with the steps?
Windows Deployment Services is a network based imaging software. The developer is Microsoft. It help us in capturing the image. How to create a Windows image for deployment?
Step 1: Right click roles in server manager to add role after installing Windows Deployment Services then click Next.
Step 2: Select Start menu and then Administrative tools and then Windows Deployment Services.
Step 3: Click Server to add. Also configure the server.
Step 4: Select the location to store images and then Next.
Step 5: Next to the server you have a plus sign, click it to get Add image wizard.
Step 6: Choose Add Install Images after clicking Install Images.
Step 7: Click add boot image after right clicking boot image folder. Give description of an image. Also give a name and confirm it by clicking Next.
Step 8: Choose Create a Capture Boot Image and then click Next.
