effieclyde
10 points
Posted on - 01/31/2013
I want to create a windows php automation script that works for windows related tasks (preferrably windows xp/7)
For example: delete the files in Temp folder of windows after every 6 hours.
Can it be done?
Any help?
How to create a Windows php automation script?
Use WinTask  which is an automation tool that allows the user to automate any Windows application or a Web page. WinTask creates effective scripts so it is not a macro recorder. WinTask provides efficient programming and it has a tool to extract data from the application under automation. It also offers OCR techniques to capture text embedded in an image and has a Windows built-in Task Scheduler. The following example is a script to test the existence of a window.  This script will be in a text file named WindowAut.txt attached to this message.
I hope this is helpful.
