How to create workflow in sharepoint 2013 using SharePoint Designer?
All of us know that SharePoint workflow makes the synchronization of work among employees much easier. But, for this, it is necessary to have in-depth detail on how to create workflow in sharepoint 2013? Can anyone tell me some easy method to bring out this task?
Answered By 0 points N/A #200388
As for an easy procedure to imply, you can use SharePoint Designer 2013 to create a workflow.
First of all, install SharePoint Designer 2013 from Microsoft Official Website.
Now, open the software from the Start menu > All Programs >
Microsoft Office 2013 > SharePoint Designer 2013
Choose Open Site on the start page of the software.
Then, enter the SharePoint 2013 site that you need to connect to, and after that, click on Open.
If asked, enter your details in the pop-up dialog box.
To create a workflow:
• Click on List Workflow under the Workflow section.
• Choose the list that you want to link with the new Workflow.
• In the Create List Workflow pop-up window, enter the required details, and set the Platform Type to SharePoint 2013 Workflow.
• Click on Ok, and your workflow will be created.
