How To Create A Zip File Online?
I want to create a zip file from the files that I have stored in my online storage called Google drive. I don't have a computer to create archives. I have only an Android tablet. How can I create a zip file online?
For you to be able to create a zip file you need to know the features of your online storage and whether it provides zip creating capability or not. In your case, you have been using google drive to create and store files online. To be able to create zip file u need to select a few files and click on the options tab on the right top of the page. And then you need to click on the archive and then specify the nameof the file that you are creating. Your zip file with the specified contents will be created in a few moments.
