How To Create A Zip File For Sending A Bunch Of Files?
I need to send a bunch of documents to my employees through an email and also want to save space and also want to consolidate the old pictures. How to create a Zip file?
Zip files help us to send a bunch of documents to employees or anyone through an email and also save space and also consolidate the old pictures. Method 1- Using Windows.
Step 1: Place all the files in a folder by creating it and then renaming it.
Step 2: Choose "Compressed folder" after clicking "Send to."
Step 3: You can repeat step 3 to select multiple files.
Method 2- Using Mac OS X.
Step 2: Choose the option of Compress by right clicking on the folder.
Notifications
