How to crop circular on Mac OS?
I have these photos.
I was thinking to crop all of it in circles, is it possible?
Please help me on how to crop circular on Mac.
I hope it is not that difficult.
Hi There are many possible ways for cropping a photo in circular shape.
You want some of your photos in this format. However.
You can try Photoshop for that.
Follow the instructions below:
1. Insert a Circle Shape into your photo
2. Right click on it and from the shortcut menu.
3. Click on Format AutoShape
4. Select the Colors and Lines tab of the Format AutoShape dialog
5. Click on the Fill Effects button
6. Select the Picture tab of the Fill Effects dialog
7. Use the Select Picture button to select the picture that you want to crop.
8. Set the crop position
9. Save Hope this shall help you
