How to customise Awstats data to a custom stylesheet ?
Hello good day everybody,
I got a question about AWstats customizes. Is it possible for AWstats to have a custom stylesheet. For a better reading & data streamlining. Can anybody who are familiar with this give a step by step tutorial how to change it?
Answered By 0 points N/A #151737
Hello Mega Joe Gardner!
You want to customize your Awstas file as your choice for better reading and data streaming. Yes, it s possible to customize AWastas file. First you need to configure a file by making a copy of AWastats model. Configure a new file named AWastats. For my site, I configured where 'My site' is but it is still your choice but generally it is the domain or virtual host name. Make your new file and must be saved in the same directory as a file in 'AWastats. pi' file.
After doing all of this, edit and check your AWastas my site configuration file that matches with your specific environment. Change the value of the logfile and full path of the web server log file. You can also use another related path for your Awastas pie directory. Change the logs type value to 'W' for test purposes of the web log file. You need to change Logformat that you created recently, if you are using extended W3C log format.
For customization, makes a list of IIS fields being logged. You need to change the direction parameters to see the reflected related path of icon directory. You need to set the site domain parameter to the main domain name to reach the web site being analyzed. Allow the update of stats from browser. Your work is finished here. Hope you will be able to customize. Keep visiting this site for more information.
Have a good day.
