jessielucyy
30 points
Posted on - 11/28/2012
I have scanned documents with black edges, and I find it very annoying, so I would like to delete it. And, I would like to convert those scanned images to PDF format after deleting the black edges. Is there a software that can do all that? I Really need your help. Can you tell me how to cut black edge in scanned pdf? Thanks
How to cut black edge in scanned PDF
Dear user,
You can use A-PDF Scan Paper to delete those black edges and then you can convert them into PDF. Follow these steps for your help:
1) Select a directory in which you will save the converted files.
2) Next, click "Scan Paper" and select scanner to convert files, click "ImageCrop…", you can also do "Settings" as Layout, click "Save to PDF", your converted PDF will be saved in the selected folder.
Hope this will help you.
Thank you.
Hi Jessielucyy,
Here is an easy way for you to remove black edge of scanned pdf.
Open your pdf file by using Adobe Acrobat Pro
Go to menu Advanced > Print Production > Crop Pages
In Units combo box: choose unit: inches, millimeter, points, …
Check Constrain Proportions if you want to remove the same value for four edges. Then type (or increase/decrease) value in Top, Bottom, Left, Right combo box
In Page Range: choose All if you want to apple to your whole document, or choose From… To… if you want to apply for some pages only.
In Apply to combo box: choose Even and Odd pages, or Even Pages Only, or Odd Pages Only
Click OK to finish
Hope this helps
