How to cut up clips from avi Mac file
Hi, I have some video files on Avi Mac format. I need to cut some clips on those files. Is there any software for do this? Please can you recommend me how to cut up clips from avi Mac file? Thank you.
You can use Wondereshare video editor to cut clips out of a video. You get a lot of video editing options and multiple trimmed video parts to help you make a great video.
You can download it here- http://download.wondershare.com/cbs_down/mac-video-editor_full718.dmg
Usage guide- 1) Add videos by choosing import on the main menu or simply drag and drop the video you want to cut clips from.
2) Drag videos from user albums to the video track on the timeline. Move the slider to a desired position to make multiple pieces of it to cut the clips.
3) Click create after finishing. You can save it in your preferred format by clicking on Format.
For more tutorials check out the video
