Is this the product’s name or file name? I don’t know what is happening with me. Can I get the proper instructions and guidance to fix this problem? I really need your help. I am using Windows XP Operating System.
Thanks in advance.
COFFEE.EXE Missing
Insert Cup and Press Any Key
How to deal with this Error?
It is very difficult to offer anything specific since you do not mention when exactly this problem occurs (what program gives you this error and what kind of actions does it limit).
I do know though that this error message is a sort of IT-joke that appears on mugs, t-shirts, web-pages etc without further explanation.
So, what I can recommend based on the information you provided that you should scan your system for malware, adware and spyware and make sure you have a competent antivirus program. That way you can probably get rid of whatever's causing this because I do not believe this is an actual Windows error message but rather is caused by something you'd prefer not to have on your computer.
