James Craig
40 points
Posted on - 05/15/2012
Hi experts,
I’ve been using Microsoft Visual Studio Team System 2008 for years. Recently, it doesn’t function properly.
I saw the “repair” option so I run it, but it did not work. Instead, an error message that looks like this appeared:
Error:
Cannot find one or more components. Please re install the application.
OK
I tried to re-install it, but nothing happened. Can you guide me how to fix this error?
How to debug Microsoft Visual Studio Team System 2008?
I checked on the error and it has something to do with the version path ATL90.dll, this is the version number of a hotfix patch to Visual C++ 2008 SP1 redistributable, in which case is not applicable to Visual Studio 2008 installed. Re-installing it won’t fix the problem. Eventually here are the steps that will fix the error:
1. Uninstall Visual Studio and then install Visual C++2008 SP1 redistributable;
2. Install the ATL security update.
You will then see ATL90.dll (see attachment)
By installing VS 2008 and ATL security it should fix the problem.
Good luck.
