ann tanner
20 points
Posted on - 04/05/2013
I am getting many problems with vbscript hex encode on my web. I need to fix those errors but I don’t know which code to use and how can I write that. Can anybody provide me the right code or the site where can I get it? Thank you in advance!
How to decide the problem with vbscript hex encode?
Following are the code for hexencode and decode .
 Hexencode function  precedes the string with  % so that it is easily used in the url. Here this hexEncode function expects the input parameter as a string and then convert  one by one every character of the string into ASCII and then into hex.
Mid , asc, hex is a built-in vbscript function.
function hexEncode(str)
           dim strEncoded, i
           strEncoded = ""
           for i = 1 to Len(str)
                       strEncoded = strEncoded + "%" + Hex(Asc(Mid(str, i, 1)))
           next
           hexEncode = strEncoded
end function
The hexDecode function accepts the encoded string and decodes it to original string. Chr, clang is the built-in vbscript function.
function hexDecode(str)
           dim strDecoded, i, hexValue
           strDecoded = ""
           for i = 2 to Len(str)
                      hexValue = ""
                       while Mid(str, i, 1) <> "%" and i <= Len(str)
                                   hexValue = hexValue + Mid(str, i, 1)
                                   i = i+1
                       wend
                       strDecoded = strDecoded + chr(CLng("&h" & hexValue))  next
           hexDecode = strDecoded
end function
Thanks
