How to decode bar code 128 windows open font?
Hello. I converted a lot of data to 128 barcodes that are ready for printing using PrecisionID. How do I decode bar code 128 windows open font and print using Microsoft Word 2007? Thanks in advance.
Thanks in advance also….
Well, Code 128 barcode fonts are easy to use. Use the Code 128 bar code fonts in C128Tools to print barcodes right in your spreadsheet, database, desktop publishing, and custom applications. C128Tools includes both TrueType and Type 1 (PostScript) Code 128 barcode fonts. It will be work
Hope this will help you…
Thanks
