How to decrypt video files
I have bought a DVD when I try to play it the message shows File is encrypted please decrypt the file. If anyone knows about how to decrypt video files then please tell me.
If the video file you had bought was accidentally encrypted, decrypting it is an easy way. What you need to do is:
1. Right click the encrypted file.
2. Select properties and then click Advance.
3. The clear the Encrypt contents to secure the data, then click Ok and OK.
That should work. However, if the encrypted file is recorded is protected by macrovision, it will state that the file will only be played through LCD. I have here a link of a video where you can watch how to encrypt and decrypt a file.
You can also watch here wherein it focus on decrypting DVD movies.
Hope this helps you.
Diane
