How to defrag hard drives on qnap?
I'm facing problem with my system. It's getting slower day by day.
I think it needs to defrag the hard drives on Qnap.
How can I do it easily?
Please, show me the process elaborately.
Thanks
Thanks
All you have to do to defragment your files is to download an application. You just have to run them then they will scan your computer. After scanning, they will ask you if you want to defragment them. I have two applications for you to consider.
1. Defragger
It is made by the same company that made the popular application, CCleaner. It is very user friendly, accurate, and does the job quickly. Most of all, it is free to download.
http://www.piriform.com/defraggler
2. PerfectDisk
Aside from defragmentation, they also monitor disk writing to prevent the production of files that needed to be defragmented in the future. If you have the money, purchase it for $29.99.
