How to delete anti spam bot?
Hi to everyone,
How to delete anti spam bot?  I would like to remove it from my computer for some reason; there are internet webpages that pop up in my computer screen which is very annoying. I think it is because of the anti spam bot software. My operating system is windows xp, give me a step by step process of uninstalling it.
Thank you.
Best Answer by George Stacy
Answered By 0 points N/A #185792
Hi Curtis Marry,
Removing or uninstalling program or software in Windows XP Is very simple.
Follow these easy steps:
1. Click on start button, locate control panel and click it.
2. Find the Add/Remove Programs and double click it.
3. On “Currently Installed Programs” find the Anti Spam bot you are talking to.
4. Click on Anti Spam bot and click remove.
5. Click ok to confirm deletion.
Hope this information helps.
Answered By 0 points N/A #185794
This is really easy to remove such programs from PC. You can go to control panel and find the program from the populated list in the “add or remove programs” section.  There you can select the “Anti Spam Bot” from the list remove that. You can also use a program named Ccleaner to delete the registry in this regard.
