This may be a very basic thing to do in Photoshop but I didn't have any single clue in doing this.
I wish someone could give me a couple of methods to do this in a simple way for me to understand.Â
Karen Li
How to delete background of pictures using Photoshop?
I could give you my favorite background removing technique. I use polygon lasso tool. Before selecting it, make sure your feather is change to 1-3 pixels.
Now draw a line at your subject and after you complete drawing line around your subject, press right click and select "select inverse" and hit the delete button.
This should have a cool extraction without even trace of background detected.
If you don't understand how to use the pen tool, you can always use the eraser tool.
It is effective but time consuming.
I'm going to try both methods now.
I'll inform you which would I prefer.
Karen Li
Okay, maybe some methods will be easier for you.
Yeah, try which method is best for you.
This is a big help guys.
I've tried both methods and I prefer to use the pen tool.
Again, thanks a lot guys!
