How can I delete browser history in Google Chrome? I have an iMac. The browser always shuts itself down when I click the clear browsing option. I get a pop up box showing something called 'problem data system configurations'. What can I do about this? Please help. thanks.
How to delete browsing history.
hello,
it is very easy to clear the Google chrome browser history; you can do this by the following steps
Click the (wrench) icon in the upper-right corner of the toolbar
Select Tools.
Select Clear browsing data.
select the "Clear browsing history" checkbox.
Use the menu at the top to select the amount of data you want to delete. Select beginning oftime to clear your entire browsing history.
Click Clear browsing data
These steps will clear Web addresses listed on the History page, Cached text of pages you have visited, Snapshots of most frequently visited pages and Any IP addresses pre-fetched from pages.
Hai Dexter Wiley,
There are so many ways to clear browsing history of a browser. The first way is to clear directly through the settings of browser. The second way is to delete the browsing history through third party software.
Here I will recommend you to use a third party software called CCleaner. CCleaner allows you to clean your system including the usage of other software also. Please follow the link to download the CCleaner for Mac version. http://www.piriform.com/ccleaner-mac. I hopes you are fine with this software & you are able to clear the browsing history.
Hope these helped.
Hai Dexter Wiley,
The second way is to delete the browsing history through third party software. Here I will recommend you to use a third party software
called CCleaner. CCleaner allows you to clean your system including the uage of other software also. Please follow the link to download the
Hope these helped.
