How to delete the browsing history in Google Chrome?
How to clear internet browsing history on Google Chrome? i need clear steps for clear my browsing history.
1.  Open Google Chrome
2.  Click on square button which is place on the right hand side of the URL text box.
3.  Then click on History panel on drop down menu.
4.  You can view the all the history on next window and then click on the clear all browsing data button.
5.  After that select the data you want to delete and click on the clear browsing data button.
Thank You
John Major.
Google Chrome is one of the most popular internet browsers in the world. It is created by Google. You can easily delete browsing history in Google Chrome.
1. Open Google Chrome and press Ctrl+Shift+Del and browsing history cleaning window will appear.
2. Select them as your wish and then click clear browsing history.
If you want to delete custom history, go to menu (located on the top-right side)>history. Then the history can be seen and you can select the histories you want to clean and click on remove selected item.
Thus you can easily clean browsing history.
Hello Dear Jack Hope,
Thanks for asking.
Dear it so much easy to clear cache of Google Chrome. You can do it in just 1 minute. Press the Customize button on very right of address bar and select history or use a short cut key from keyboard.Â
Press key combination of CTRL + H and press "Clear all browsing data" when you will press this button. You will see this window.
Mark all the categories and press the button highlighted in image.
Thanks
