Hi Techyv Friends,
I am using Google Chrome as my default browser. I got drawplus toolbar in Chrome, through some application. Now I need to remove that, How to delete drawplus toolbar from my browser. And also tell me how to delete drawplus banner.
Thanks in advance friends,
Christopher A Hopkins
How to delete Drawplus toolbar
Hi Christopher,
There are multiple ways to delete drawplus toolbar.
Solution 1: Enable or disable toolbar
1) Open the chrome webpage
2) Go to 'Tools' > 'Add ons' > 'Extensions' and locate the toolbar
3) Click 'Remove' and the toolbar is removed
Solution 2: Remove through Control Panel
1) Go to 'Start', Click 'Control Panel'
2) Go to 'Add/Remove Programs', select the name of the toolbar
3) Click 'Remove'
Solution 3: Third party applications
1) You can use the third party tools like CCleaner, Revo Uninstaller to perform the uninstall
