B.lie
25 points
Posted on - 08/19/2016
Hi everyone! So, I am stuck in a very serious problem. From some years ago, I have been using different Email IDs, but now I have created one as official and transferred all my Mails on it. But, I found that many of them have been got repeated. So, please provide any solution on how to delete duplicate Emails in Outlook 2007?
xalopez
How to delete duplicate Emails in Outlook 2007for free?
If you want software that can be with you for always and gives free service, that is, does not hook you up after giving a free trial, you should use the software mentioned below:
1) Outlook Duplicate Items Remover:
It works on all versions including Outlook 2002, 2003, and 2007.
ï‚· First of all, download the software. It will be a small 2.11 MB file. Shut down the Outlook to complete the installation.
ï‚· Now, restart the Outlook and see click on the ODIR menu.
ï‚· Next, select the folders that you want to run ODIR against.
 Hit the ‘Remove Duplicate Items’ button, and let the app do its work.
 When the process is complete, a sub-folder in the name of ‘ODIR_Duplicate_Items’ will appear.
 Now, it’s up to you whether you want to keep the folder or kill it.
ï‚· Read the image above to know how ODIR works.
