anonymous
7060 points
Posted on - 03/27/2012
My mother gave me a used laptop and when I ran the command prompt, the path displayed : C:Documents and SettingsEphraim How to remove the Ephraim? WHen I tried deleting it, it prompted a message, that it cannot delete the folder because Windows is using it.
How to delete this folder?
Hey Dear!
You cannot delete this folder because this is the Administrator folder. As you have mentioned above that your mother gave you a used laptop so it means that this laptop already has Operating System installed in it. The person who was using this laptop before, had installed the Operating System and the name he used for Administrator was "Ephraim". If you want to delete this folder, you must have to re-install the windows of your laptop and then give the name of your choice to the Administrator. You will not see Ephraim then.
I hope you understand it.
Thanks
abirsun
You can delete this folder. at first you need to ctrl+alt+delete then start end task and go to process and then you will find the desired programme that are running and select it and press End process. Now you can delete your folder. May be this process will be helpful for you.
