Logan Mills
Posted on - 06/25/2011
Hello!
How can  I  delete Google Chrome search history? I found the wrench icon on the right side of the address bar and went to tools. That wasn’t right. I finally saw the History sect and saw  the list of addresses I’ve visited, but where do I get them? Am I missing something?
Thanks!
Paula79
How to Delete Google Chrome History
STEPS TO CLEAR YOUR ENTIRE BROWSING HISTORY:
Select the wrench icon on the browser toolbar.
Click tools.
Select the Clear browsing data.
A dialogue will appear,check the Clear browsing checkbox.
At the top you will see a menu. Select the amount of data you want to delete. Select the beginning of time to clear all of your browsing history.
Lastly,click Clear browsing data
THE FOLLOWING INFORMATION WILL BE REMOVED WHEN YOU CLEAR YOUR BROWSING HISTORY:
The cached text page you have been visited.
The pictures of the website you always visit on the new tab.
Any kind of IP address pre-fetched from page you have visited.
lee hung
75 points
Hi Logan!
To delete the search history from Google Chrome, follow the steps below:
Click the Wrench icon found on the upper right hand corner of Google Chrome near the X button.
Select History
A new tab will be opened with the address of chrome://history/
There you will see all of the websites you’ve opened
Click the Edit items found on the upper right hand corner
Press the button of Clear all browsing data
This will open a new tab with the address of chrome://settings/advanced
This tab will have a small window that says Clear Browsing Data
On the Obliterate the following items from: you may press the drop down menu and choose from:
the past hour
the past day
the past week
the last 4 weeks
You may also select what items in the history you want to clear:
Clear browsing history
Clear download history
Empty the cache
Delete cookies and other site data
Clear saved passwords
Clear saved Autofill form data
Additionally, you may also clear the Adobe Flash Player storage
The Adobe Flash Player also stores data from websites where Flash was used in order for easy navigation the next time you visit that certain website
Once you have made your selecting on the time frame and what to delete, press the Clear browsing data button
When pressed, you will see a blue line going around beside the button indicating the process being executed.
The small window will automatically close when it’s done.
Delete through the Control Panel
Alternatively, you may delete the browsing history along with the temporary internet files and cache through the Control Panel
Open Control Panel
Open Internet Options
On the General tab, under Browsing history, press the Delete button
You may choose what to delete just like in Chrome.
Press the Delete button below the categories once you’ve decided to go ahead with the deletion
You may also use third party cleaners such as CCleaner that will help you delete the temporary internet files and cache.
Hope that helps. Good luck!
jhyn08
Hello!
I would like to help you. I have also encountered that before. Please just follow these steps. It helped me clear my browsing history.Â
Clear Browsing History:
Go to spanner icon ( wrench icon on the upper right of the screen)
Go to tools
Click "clear browsing history"
Select the "clear browsing history" in the checkbox.
Select the past hour" or "beginning of time"
Then click the "clear browsing history"
If you want to remove some items in your browsing history. Please follow these steps:
Select the spanner icon
Then, history
Select "edit items"
Check the "past hour" or "beginning of time"
Then lastly, "clear browsing history"
Hope it would help you.. 🙂
Jennielyn
IT student
