How to delete images from dropbox?please help
Hi guys, I use google plus as I'm blogger all my accounts are connected to my blog page including goolge plus the account which I mainly used to create blog.Now all the images I upload on blog saves in my drop box even personal and blog pictures directly in my drop box in PC and mobile too which is eating up my mobile memory very quickly.Please help me how to remove these settings and delete images from dropbox as there is no option to do that
Answered By 0 points N/A #187559
Follow the steps below to fix the issue.
  • Sign in to your account in Dropbox website.
  • In the left side list, click the album.
  • Select the images you want to delete.
  • A check mark will appear on each selection.
  • In blue bar, click on the remove from album.
  •  A pop up window will be appeared.
  • Click "remove" in that window.
  • Your image will be deleted.
You can delete the image by another method after signing in to your account. Follow the given steps.
  • Open the album from side bar.
  • Double click the image.
  • It will appear with full screen.
  • Click on the little "gear" icon at the right side in bottom.
  • Select "Remove from album"
There is another method to delete the image permanently. Do the following steps.
Delete-image-from-dropbox
  • Sing into your account.
  • To select the file, click on the empty space to the right side of file's name.
  • Click "delete" in the action bar across the top of the file browser.
  • In the file browser click on the "Trash can" icon.
  • It show you the deleted items.
  • Select the file (image) and click on "permanently delete"
  • In this way your image will be deleted.
