anonymous
7060 points
Posted on - 08/09/2011
I am Opera user. I am browsing it for few months. Now I remove the all history of Opera of my computer. But I do not know how delete history of this software. Now I need the procedure of deleting history.
LaraP
How to delete my Opera history
 Procedures in removing history (Opera browser):
 Press shift + control + h key from your keyboard.
Opera will open History tab then delete
or
Tools tab from Opera browser
Select Preferences
Select Advanced menu
Select History from the left side part of the Advanced window
NOTE: If Opera menu bar is disabled, Click Opera button located at the upper left corner of the browser then Select Show Menu Bar.
LaraP
hillsong
Opera browser cache stores images, videos, addresses and other parts of websites that you accessed while you are surfing, temporarily. To remove this history, you need to:
At the menu bar Select Menu  then  Tools
Scroll right and down and select Private data
select Delete cache at the right hand side of the dialog box
Select Delete logins, Delete history and Delete cookies.
Opera gives an option to limit data you want. This is called caching. To do this:
Select Menu > Settings, select Advanced tab/menu and select Cache size (Small/Medium/Large) and then press "OK".
