Trevor Jhon
40 points
Posted on - 10/18/2012
Hello experts,
How to delete recent documents dos command? I want to delete all my recent files using DOS command, I am curious on the DOS command prompt and how it works in a proper deletion process. Give me some information that will possibly help to feed my confusions.
Deleting file using Dos Command just put an extra careful. I will give you the syntax in deleting your recent documents. If you’re using Windows 2000 and Windows XP here’s the command and the steps to follow:
1. Click the start button.
2. Click Run then type CMD. It looks like this when you run the CMD windows.
3. Type this syntax: del [drive:][path]filename
or delete [drive:][path]filename
Example: Del C:documents and settingsquestion and answers.
Hope it will help and feed you.
DOS program has some different commands then a normal operating system like windows, but still we are able to delete or create any file or folders by using DOS program. “Del” is the command to delete any file by using DOS program. Please press the Run button from the start button and type COMMAND then a DOS program window will be opened.
Here you can type your deletion command Del the then file path to delete, like following:
Del D:MobilePhotos/mypic
