How to delete songs from napster collection?
I can add music to My Napster Library without issues, it's just that I cannot remove it when I want to. How to delete songs from napster collection?
Hi Elsiet,
There are many ways to delete music from Napster few and very easy ways are copy music which you want to store and put it in new folder then you can delete from default Napster songs folder. It will only assume that you keep all songs in it's library folder but once you delete its gone.
Second method go on napster.com login and delete the music which you don't want.
Under the display, press the middle key on CR100 Napster name came while playing the song you can remove
Browse you library and artist then album or any track you want after then in main view pane select the track which you want to delete, at the bottom of screen a button to delete track.
Hi Elsietbrown
It is online music store that offers services to download or listen dissimilar approach of songs. Most of the songs are under the safety of digital rights managements (DRM). The main purpose of DRM is to continue you from them on any of your transferable music devices like iphone, and PSP.
For removal follow the following path
Under the display push the middle key this is named as “NAPSTER” as playing song you wants to remove.
Or the other alternative is to go to Napster.com log in there and remove the song of your choice.
THANKS
