How to delete temporary files in my laptop?
Hi friends,
I want to know how to delete temporary files in my laptop. The laptop is Sony Vaio and I think its temporary files and browsing data is saving that is making my browsing visible when checked folders. So please help me how to change its settings and delete temporary files too.
Best Answer by
Answered By points N/A #186381
Temporary files are important for programs to run perfectly. But temporary files which are old enough are of no use except making the system slower.
In order to delete the temporary files,
1. From start menu, type “%temp%” >> hit Enter.
2. Delete files which are more than 7 days older.
In the same way, you can delete another folder files called “Prefetc” at “C:WindowsPrefetch”.
But deleting the temporary files manually might cause some malfunction in your system. So, using any good tool is recommended. You should use CCleaner, Wise Care 365 etc. You can delete your temporary files, browser junk files, invalid registries with a single click.
Answered By 0 points N/A #186382
To delete temporary files from your computer, first go to my computer and then go to C drive and follow this sequence
C:Users(UserName)AppDataLocalTemp
Delete those files which you want to delete.
Another way is that click on the windows button and at the search bar type Disk Cleanup. There you can select your desired folder which you want to clean up and all the temporary files will be deleted.
Answered By 0 points N/A #186383
Hi Jack M Gates
To remove your unwanted files from your system there are many ways. Pay a visit this Techyv post to get more ways to remove your unwanted files.
Want to remove some unwanted files
