I am new to Adobe Photoshop and was hoping if someone will guide me with steps involved with designing Adobe Photoshop event program template. Any kind of help would be appreciated in this regard.
How to design Adobe Photoshop event program template?
To create an Event Program template using your Adobe Photoshop, you can choose from several online templates from Adobe | Photoshop Templates or you can create your own. If you want to make your own, select a paper size of 8.5 x 11 inch. Decide on what type of event program you are going to be creating.
It is commonly a letter size folded in half or something similar to a greeting card. Setup the text and columns. Select your design and colors. Select one that is best for the theme of your event. If it is a formal event, try the combination of black, white, and red. If it is a modern event, select from the shades of gray, blue, and orange. Write a meaningful text about the event. Add some image and put it on the cover page. Transform your image using the effects in Adobe Photoshop. Then finally print your design.
