How to design adventure time wallpaper for iPhone?
I want create my own adventure time wallpaper for iphone. Please tell me how can I capture photos and how to get correct dimensions?
Hi James,
You want to know how you can create your advance time wallpaper on your iPhone.
I like to say it's very easy to do it's not about capturing the photo. If you want to do this you need Photoshop Software on your PC. Opens the photo in Photoshop and Crop it .Put it 320 width and 480 height. It's the 72 number Resolution options of photoshop. Then you go to the photo gallery and select the photo than set it as wallpaper to click on the use wallpaper button. I also give you some link which can help you .
http://ipod.about.com/od/iphonehowtos/ht/how-to-set-iphone-wallpapers.htm
