How to design boots for FIFA 12 products?
I wanted to edit the different boots included in FIFA 12 and other products as well. I am hearing that this is possible. Can anyone help me how to design boots for FIFA 12?
Hello Hall.
There is a software named Creation Master 12 that helps to customize everything in FIFA 12. From player look to boots and stadiums and almost everything. what you need to do is just download and install Creation Master 12 and you will be ready to customize the boots and everything you need to. Hope it helps.
Editing boots for FIFA 12 products is possible.
Just see this Youtube video
It is a video tutorial on how to edit and add custom kits to FIFA 12 and can also work on FIFA 13.Â
Please watch it because it is a very helpful video. Hope I helped.
