Hi TechyV Experts,
I am designing a website for my college as a project. Can you please help me in how to design forms where I can put password value also. Please tell me what are the form design best practices, so that I can build the best project in my college.
How to design forms on website.
Dear Anthony,
There are several ways to design a website. I recommend using Web Studio 5.0.
It is a magnificent software which can be used easily to design good software using many templates and Java scripts, and it has a free trial period of 30 days.
You can purchase it after trying it out and gaining your approval.
Best regards,Dear Anthony Anthony,
There are several ways to design a website, I can recommend to you using web studio 5.0.
It is magnificent software which can be used easily to design good software using many templates and Java scripts, but it is free trial software for 30 days.
You can purchase it after trying it and gain your favor.
Best regards,
Don Muench
Hello Anthony,
Website designing is interesting thing to do. As you have mentioned you want design a form where you can put values and password. There are so many sites are available from where you can find many templates and scripts. To make your project best and the form looks good you can use this software. You can check on template monster blog for some tips to make your form good. Hope this could be a help.
Good luck.
