How to design our own flash video presentation template?
Hi to all graphic and template designers. As many flash images as well as video templates are available on the internet which has beautiful color, graceful graphics and designs. But all of these were designed already and we will have to edit and use them only just. I want to create new flash video presentation template as my own ideas and requirements. Are some tools available on the internet which could fulfill my goal? Some guidance is needed.
Answered By 10 points N/A #168078
Hi Goff,
If you want to make your own Flash Presentation online, I can recommend you this page: https://www.toufee.com/
It is easy to use, you just follow the steps. You don't need to download any software that may cause problems to your PC, also, it works on Windows, Linux and Mac OS.
At this link: http://www.geovid.com/ you can find software that converts your Power Point Presentations to Flash presentations, or any video-format to Flash video. Your job is to choose picture or pattern and create your own template.
I hope you found this useful.
Best.
*links may not work after few months
