How To Detect And Remove Adware From My Browser?
My computer suddenly pop-up ads and keeps sending me to the wrong Websites. A lot of time gets wasted in closing those and getting back to work. Please tell me how to detect and remove adware?
To remove the malicious software that has infected your PC drastically, follow these instructions:
1. Restart or Boot your device into ‘Safe Mode with Networking Support’.
2. Now, open your concerned browser and check for add-ons and rogue extensions. You can look for it under your browser’s settings/tools.
3. Check the search engines, start page and any other defaults. If you find anything unfamiliar, delete it at the very moment.
4. Press Win + S, and then type MSConfig to launch the System Configuration panel. Search for programs that are set to start automatically. Remove anything that you don’t recognize.
5. Save the settings and reboot your computer. 6. Download and run the scan with Malware Bytes Anti-Malware.
