How to detect and repair disk errors
Hi expert, Last two weeks my PC working slow. My operating system is Windows vista. How to detect and repair disk errors? Is there specific software to solve this problem? Provide the download link.Thank You.
Hi Kristin Runaldou,
Thanks for asking us.
Window has its own utility to detect and repair the problems in disk. Each window that is designed and produced by the Microsoft has this utility.
It is so much easy to run this utility.
Please open My Computer or type three dots in RUN and press enter.
It will open My Computer, then right click on the drive which you want to check and repair for Bad Sectors, Bad Clusters and other system recovery.
So now choose properties, it will open the property of drive. Go to tools tab, here you will see three options.
1. Check Now.
2. Defragment Now.
3. Back Up now.
You have to choose Check now. It will take sometime and you will get the desired results.
Thanks
