Hello techyv,
How to detect devices lenovo bluetooth? I got my new lenovo mobile phone last week but until now I still having a hard time getting connected to nearer devices. Can you guide me along the process of connecting to other mobile phones via Bluetooth? There are some files that needs to be transfer.
Expecting some help from you guys.
Good day Vanessa,
Here are some of the answers that might help you with your problem. First go http://support.lenovo.com/en_GR/default.page to enter your serial number. it will tell you your configuration and tell you whether or not it has a bluetooth. it will also guide you along the process of connecting to other mobile phones via bluetooth. hope this help. god bless and thank you
If you have a Bluetooth-capable device like a Smartphone and you want to connect to other devices, you need another Bluetooth-capable phone to perform the connection. To perform the connection, both devices must enable Bluetooth connection and then perform pairing. When doing the pairing, one of the two devices will perform a search for nearby Bluetooth-enabled devices.
In order for your phone to be located, you need to give it a name. You can do this by going to the Bluetooth settings. Once your phone is located, the user needs to select your phone’s name then perform a pairing. Just follow the instructions to perform the pairing successfully.
Though Bluetooth allows you to connect to other devices, it cannot be done without the other person’s permission because pairing has to be done manually. Another downside of this connection is the version of Bluetooth on either device. When the Bluetooth version is very old than the other one, you won’t be able to transfer files between devices.
