sideno leba
Posted on - 07/04/2019
Windows 10 is the latest version for windows users. But in Windows 10 we are often getting updates. The problem of these updates is, there is no notification saying that there is an update to the version. What happens if I don’t update to the new versions of the windows?
How Did Windows Add With Extra Features?
As Windows 10 is stable, it won’t show any notification for the release of new versions. You should manually check for the updates. Every version adds a new feature to the windows, which improves its performance and adds new features. If you want that feature, you must update it. Before the update, you need to know which windows version you are using. The details of the new version will not be available anywhere. It only asks the version is home are business. The current version and the installing version should match. You can use the windows update tool to install.
