ave broers
70 points
Posted on - 06/10/2015
What are the special features of a Dell Optiplex 3020 Quard-Core Micro desktop? Would you prefer the towel version of this same machine over the desktop version and why? What are the advantages and disadvantages of using each type or version? How is the Dell Optiplex 3020 Quard-Core Micro PCs different from Dell Optiplex 3020 Core i5 CPU PCs? Please help me explain this in simplest term s to grade six students now learning computer hardware?
How Different Is Dell Optiplex 3020 Quard-Core Micro desktop From Others
The Dell OptiPlex 3020 Micro PC desktop comes pre-installed with either Microsoft Windows 7 Professional (English or French) or Microsoft Windows 8.1 Professional 64-bit. It runs on fourth generation Intel Core i5 4590T Quad Core 2.0 GHz processor, built-in Intel HD Graphics 4600 GPU, 4 GB 1600 MHz DDR3 RAM, and 500 GB SATA hard drive. Unfortunately, it doesn’t support optical drive for use on CD and DVD discs.
It supports Intel Dual Band Wireless-AC 7260 802.11AC Wi-Fi, Bluetooth 4.0 LE Wireless Card, 10/100/1000 Gigabit Ethernet, two (2) USB 2.0 ports, and four (4) USB 3.0 ports. They offer 3-year basic hardware service with 3-year NBD limited onsite service after remote diagnosis. This micro PC has only one (1) memory card slot. So if you want to upgrade the memory to 8 GB, you need to buy a single 8 GB memory module.
Also, if necessity comes and you need to use an optical drive probably for installing software or watching movies, you need to purchase an external DVD or Blu-ray drive that you can fit to one of the USB 2.0 or USB 3.0 ports.
