Whenever I plug my iPod Touch to my computer, iTunes automatically syncs. I know this is a feature of iTunes but I'm constantly updating my iTunes library and I do not want to update the library of my iPod automatically. What can I do to stop the automatic synchronization, because sometimes I just want to charge my iPod.
How to Disable Automatic Sync on iTunes
Hi James,
Good Day to you!
I understand your point that there are times that you want to plug-in your iPod Touch in your PC, to just simply charge it, and you don;t want to sync it, here are my best solution for you to disable the auto sync feature.
Before you attach your iPod Touch, go to iTunes.
On your computer, go to the menu iTunes > Preferences > Devices.
When you are there you will see a pop up window, locate the icon or a tab that named Devices.
Underneath the box, you’ll see there a check-box that says: Prevent iPods, iPhones, and iPad from syncing automatically.
Have it Checked and click OK located at the bottom of the window.
I hope this will help you in turning off the auto sync.
Enjoy!
